dhcp-match-message-type
Configures the DHCP message type to match
- Access Points:
AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
AP7662, AP8163, AP8533.
- Service Platforms:
Syntax
dhcp-match-message-type [all|any|discover|request]
Parameters
Specifies the DHCP message type to consider for
matching
all – Matches all message types: discover and
request. Indicates that the fingerprint is checked with both the
DHCP request and the DHCP discover message.
any – Matches any message type: discover or
request. Indicates that the fingerprint is checked with either the
DHCP request or the DHCP discover message.
discover – Matches discover messages only. A
match is made only if the discover message sent by the client
matches the match criteria set in the client identity. Values
configured for request messages are ignored.
request – Matches request messages only. A match
is made only if the request message sent by the client matches the
match criteria set in the client identity. Values configured for
discover messages are ignored.
nx9500-6C8809(config-client-identity-test)#dhcp-match-message-type all
nx9500-6C8809(config-client-identity-test)#show context
client-identity test
dhcp 2 message-type discover option 2 exact hexstring 012456c22c44
dhcp 1 message-type request option 60 exact ascii MSFT5.0
Related Commands
no
Removes the DHCP message type to match
